Left clicker on my logitech m170 is not responding to clicks anymore
How can i fix the left button that seems to not work, do i have to rewire something? I dont have any clue of what to do, everything seems to be in place
좋은 질문 입니까?
좋은 질문 입니까?
If you press harder, does it works?
one thing you can try is to open up and check on the buttons and microswitches.
check for any dry solder joints or worn out micro switches on it.
those micro switches sadly now has a limited lifespan..
You can use the multimeter in beep community (digital) or resistance (analog) to test the microswitch.
depress the switch and it should beep, or the analog pointer will move.
I would suggest you to replace the micro switch, which you can order it from ebay / aliexpress, etc.
To replace the micro switches, you need to have some soldering skills, perhaps I say it is not so difficult, else you can ask you friend for help.
해당 답변은 도움이 되었습니까?
Hi, i have tons of logitech mouse having this problem. My simple solution is to open the mouse, then i will normally add a layer of small size masking tape to the side of problematic clicker. Add on a layer of masking tape until your are satisfy with is clicking respon.
해당 답변은 도움이 되었습니까?
do you have any photos how you do that? would you be able to send it to omid89 atsign gmail d0t com
this model was released back in 2016 when Logitech used subpar switches, unlike today. And those switches generally wear off faster which is why you are facing this issue. Now you have two options - One, try what @isk2021 suggested and see if it works using the click test on https://cpstest.pro. Secondly, if you have the budget, you can simply buy a better mouse - maybe anyone from the logitech's G series.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 6
30일 전: 35
전체 시간: 1,188
