주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1041 질문 전체 보기
Power button doesn't click anymore
The power button on the iPhone 6s+ from my mum doesn’t click anymore. It still registers but the feedback is horrible. What exactly do I have to replace? Isopropyl and compressed air didn’t help.
Somewhat related story:
She was fine with it but now she dropped the phone in the toilet and while I have everything open I can replace the button as well. Actually getting that to work again was/is quite a bit of work. Got rid of all the water inside, no visible damage. It worked fine but rebooted by itself randomly and didn’t charge at full speed and stopped charging after a while. I thought I didn’t get everything and opened it up again. While doing that I think I broke the cable to the digitizer (touch screen not working but image is fine). Either way same result for the phone itself. Dumped a ton of isopropyl alcohol into the phone and some got into the screen (rip screen even more). Now I got out my old battery from a few years ago (replaced it with an ifixit one after the capacity got low) and DFU mode reinstalled iOS. Now it charges just fine and I think it doesn’t crash anymore. So now I ordered a new battery and a refurbished screen (rip me)… and I hope everything will work. So while I am waiting I can just as well order whatever I need for the home button.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Aye caramba.
Is the home button damaged too? If not,BE VERY CAREFUL WHEN REPLACING IT. If it breaks,you lose touch forever. Just be thankful it’s a 6s. Anything later gives a problem with a new home button period.
The power power button requires the whole logic board to be taken out!!!! This will be a very very difficult task for someone who’s never don’t it before. You will want to make sure YOU DO NOT get the screws mixed up no matter what. Taking screw damage is real. The little metal rings attached to the logic board that look like a bolt(silver) only go so deep,with nothing under but board. If you use too long of a screw it will dig in and destroy micro traces(wires) internal to the board since it’s like 10 layers. You should watch YouTube videos. But it requires taking the board out,and the battery. It’s one flex cable. So removing the flex cable attached to the power button/volume(this is why you have to remove battery too.) set. It’s a pain in the ass. You can use assistive touch instead though…but it has an icon on screen. This reduces the likely risk(no insult meant) of something going wrong. You’d need heat to take off the battery. You don’t want to bend it no matter what.
You you will want the board out either way really to clean with alcohol. There’s no guarantee that no water got under the shields. But you can clean it the best YOU can. DISCONNECT ALL fpc connectors and clean repair very well. Have you checked the power button from the inside?
My mom dropped her iPhone in the bath and it still worked(at the time about a year ago I didn’t even know how to open them.) and it survived to this day!!! It did have an otter box though. But it didn’t power on. I think the otter helped reduce the amount of water,but either way we replaced the screen after many videos and it works.
Alcohol is bad to get in a speaker(on bottom of phone). This can move flux on the area and get crap into it. It could effect the speaker.
Make sure you don’t connect anything to or disconnect anything from the board without FIRST disconnecting the battery.
해당 답변은 도움이 되었습니까?
점수 1
댓글 19개:
I already took apart almost everything twice (second time broke touch input on the screen) and this was not my first iPhone that I took apart so I somewhat know what I am doing. I will make extra sure to always put the screws back in correctly, thanks. The home button still works just fine as far as I can tell. The speaker seems to have taken no damage from my isopropyl and I am quite certain that I got all the water out (took the mainboard out and used a lot of compressed air in the gaps of the metal shielding).
I am pretty sure that I will hopefully fix all problems with a new battery and screen (putting the camera stuff and home button in will probably be quite annoying though). The power button still works but there is no real click to it so it feels horrible to press. What exactly do I need to buy? Just the physical button of the case? Or do I need to replace the entire flex cable (or both)? There was no visible damage and compressed air and isopropyl alcohol did nothing to improve the feedback.
Hey. It depends. It could be the button itself that’s part of the flex cable that isn’t clicking correctly,or the metal cover of the button could have gotten some corrosion in it. It may not have to be replaced technically,since it could be that corrosion is in there blocking the metal cover(the part you press and see on the outside of the phone that goes over the tiny button soldered to the flex cable) from being able to move in And out of the power button slot correctly. If this is the case it just needs to be taken apart and cleaned to make it click again. The metal button cover won’t be damaged from water. But the clicking button(the actual button attached to flex cable) may have gotten corrosion or crap inside of it. In this case you’d need the volume/power button flex cable. So the metal “button” you see on the outside just goes over the flex cable button. The metal won’t be damaged,but could have crap or water deposits between it and the button,in which case you need to buy nothing.
Ifixit just glitched and lost my other long comment...
@skyethespy The power button is like that for like half a year, way before the water damage. I tried compressed air and isopropyl but it didn't change anything about the feel. It looks clean to me but I didn't take it out yet. The power button flex cable only costs like 8€ so I would probably just buy it and if it turns out cleaning was enough just return it. I don't want to take everything apart twice in case I actually need to replace it. https://smile.amazon.de/MMOBIEL-iPhone-P... will this work? What are the other components on the cable?
Other components are mic for video recordings and back camera flash...
댓글 14개 더보기
댓글 달기
귀하의 답변을 추가하세요
Karavusk 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 1,227
