주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 더 큰 Apple MacBook Air 노트북 입니다.
465 질문 전체 보기
Compatible screen between MacBook air
Hi, I got a macbook air mid 2013 a1466 with a broken screen. It's hard for me to find the parts (only the screen, not the whole screen assembly). Can it be replaced with other macbook air screen which have the same series a1466 only different year?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Nic - Where do you live country and major city nearest to you?
Maybe we can aim you to so a closer source for the part
Apple used the same screen across the 2013 through 2017 models. Here's the needed assembly MacBook Air 13" (Mid 2013-2017) Display Assembly Apple P/N 661-7475
The biggest problem is getting the bare LCD panel to arrive intact! As unlike the full assembly it is very fragile! Here's the note from one of my part sources:
This is an extremely fragile part comprising just the LCD glass panel and controller board. It does not have any metal enclosure or backing sheets and so relies on the original backing within the MacBook Air lid being intact and useable.
Because of the difficulty in fitting this part, the risk is entirely with the engineer fitting it. The warranty does not cover accidental damage during fitting.
MacBook Air 13" (Mid 2013-2017) Display Assembly 이미지
상품
$314.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Hi, I lived in Jakarta - Indonesia. It's hard to find a good macbook parts in here, probably will go to Singapore next week. Any recommendations store in Singapore? Or does it save for me to buy it from ebay or aliexpress, just the screen without the backing panel?
Sorry don't know of any shops there. Check the web for shops as that might be just easier than trying to fix your system your self. If you have a friend there see if they know. Maybe @benjamen50 who lives in Australia might know.
댓글 달기
가장 유용한 답변
Yes, in theory it wouldn’t be a problem, in practice removing the panel from the frame without damaging it is a very challenging task as it’s glued in place. I wouldn’t recommend at all to go that road if you asked me.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
What models can I used for the replacement? I already removed it without damage, with helps from hot gun and steady hand.
@Nic Yaakov Durant, Sr Any Macbook Air 13" should do, as far as I know the panel specs have never changed.
@arbaman - the 2018 & 19 models are different!
댓글 달기
귀하의 답변을 추가하세요
Nic Yaakov Durant, Sr 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 710
