주요 콘텐츠로 건너뛰기
The iRobot Roomba 880 is an autonomous vacuum released in 2013, with greater power and cleaning capabilities compared to the previous models.
4 year old Roomba 880 squealing while running
UPDATE:
thank you for all your responses we determine that it was the side brush motor. Ordered a new side brush motor and No More Squealing! YAY
Again, thank you all for your help
My 4 year old 880 has starting squealing/screaming while running. I’ve cleaned everything but still scrams. I’m afraid it’s the motor, any suggestions
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Thank you! That’s what we were thinking too.
댓글 달기
답변 2개
선택된 해법
It’s probably the motor, if you’re an expert, you should take it apart - but for most of the time you should ask the previous owner, or company if they can fix it.
Again, what I always say “look it up!”.
Looking it up might not work…
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thanks for seeing this! :)
댓글 달기
I had a squealing noise in my Roomba too. which I could trace down to the gearing of the extractor brushes.
The motor was slightly displaced so that the gears didn’t connect properly. I was able to fix this temporarily by adjusting the motor with a piece of plastic. but the gears were worn down already so that I had to replace the extractor housing (including motor and gearing). was not a lot of trouble and is totally doable!
I found the housing in the Roomba shop, but it was a hidden link I only found using google… I am not shure what the situation is where you come from but here in Germany this was also the cheapest offer!
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
https://shop.irobot.de/de/cleaning-head-...
thats the part I bought for ~45€ while Amazon and Ebay were >60
댓글 달기
답변을 추가하세요
SueWormington 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 14
전체 시간: 3,088
