주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1366 질문 전체 보기
iPhone 7 Plus restarts after 3 minutes on 1 % percent battery issues
Please I need your help .. My iPhone 7 Plus screen fell and had a hair like crack but it did not give the phone any problem .. after one month
My Iphone started acting up , it restarts after every 3 minutes when I’m using it and comes on at 1 % when it was charged fully well ,
sometimes the battery percentage goes up and drains down and when it reaches 20 percent most times it stops doing the random restart ,
also when I am charging it it might stop charging and sometimes charge when I replug the charger ..
I have tried my best by doing a reset on my phone and I’ve updated the software to the latest IOS (12.3.1) and also deleted apps and erased all settings , but I’ve not changed the battery .
I don’t know if it’s a battery problem or it’s a software problem or something else
please what is the solution to my predicament??
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
You might have a bad part or a faulty component/circuit on the logic board. There’s no way to tell exactly what got compromised with the drop without testing or replacing parts, but that requires parts available. You may try replacing parts starting with battery and lightning assembly that seem the most likely candidates without spending to much money, but be also ready for failure. Alternatively you can walk in a repair shop and let them take care of the troubleshooting.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Nedu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 514
