주요 콘텐츠로 건너뛰기
Third generation Surface Pro tablet, released June 20, 2014.
123 질문 전체 보기
Casing has chipped corner, what can I use to patch it?
Hiya fixers. Attempting to replace a screen on a Surface Pro 3 (1631) and while trying to remove a bend blocking the new screen from going in, a tiny piece of the corner sheared and chipped off! I can now fit the new screen in, but now there is a small section in the corner where the under screen is exposed. It is also quite sharp where it sheared. I plan to file it down enough to where injury will not occur from handling it, but wondered if anyone had an idea of a substance I can use to patch this tiny section. A material that would be malleable at first but then become strong. Last resort I will use a case that covers the corner
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Look up amazon for SUGRU. It’s a malleable putty-like silicone glue which forms a flexible yet reliable glue. I used it to fix a hole in my cars dashboard for example.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Joe Two Beards 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 36
