How to check fluid level on transmission
2013 how too check transmission fluid
좋은 질문 입니까?
You cannot check or add fluid as described there is no dipstick that you can just grab and check fluid! You have to get under the car and remove an engine mount to get to the dipstick which bolted in with 12mm bolt ! It is a poorly designed transmission with no fill tube for easy access. $250-$400 for transmission service!
해당 답변은 도움이 되었습니까?
You literally remove 1 7/16 bold plug my guy.
Thus engine and transmission is GMs' most defective ever
Transmission Fluid Level Check Chevrolet Equinox (2010-2017)
해당 답변은 도움이 되었습니까?
There is no DIPSTICK on the 2011 Chev Equinox!!
^^this^ and this answer should be removed
You couldn't be much more wrong than you are.
You know, people rely on this information to be correct it's crazy that this got by somehow. This answer may be right on 99% of vehicles but the Chevy equinox is not one of them. Because it has no dipstick. It has a sealed system that forces these car buyers to take it to a shop to check the transmission that's crazy. And in mechanic terms that can cost a car buyer from 200 to $400 just to check it.
You have to remove 3-4 bolts off of the cover underneath the car. You cannot access your dipstick without removing that cover and will have to have it on a lift to get an accurate reading of the fluid level. Look for the full video on YouTube. ”How to service Chevy Equinox transmission fluid by Santer Auto Repair LLC.
해당 답변은 도움이 되었습니까?
how can i fix the 2020 transmission fluid and change the fluid
24 시간 전: 13
7일 전: 79
30일 전: 443
전체 시간: 37,286
댓글 2개
Where is transmission dip stick located
Howard Prigg 의
There's no dipstick,under the car, there's a bolt, a lady can't get to that,but I myself watched my dad,I can't afford 400 to a mechanic. I'm going to do it.ty to those who showed me on here.
Juanita Aldape 의
