주요 콘텐츠로 건너뛰기
모델 A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, 또는 3.06 GHz Core 2 Duo 프로세서
433 질문 전체 보기
Power adapter - multiple choice, please help!
Hi!
My power supply is faulty on my iMac and I need a replacement. The faulty supply inside my 2007 24 inch iMac is a LiteOn PA 3241 02A1.
In my research, it appears that another power supply is also a compatible replacement. A Delta ADP 240 AF B. These seem to have been fitted to the 2008 version of the iMac 24 inch.
Is this the case that either can be used as a replacement for my 2007 iMac?
Thanks for your help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Apple contracted both companies (Delta & LiteOn) to make power supplies. As long as you get the correct one for this series you’ll be OK. Here’s a good rundown of the Apple P/N’s per each model. This is from PowerbookMedic’s parts listing 250W power supply
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Thanks for this information @danj . That’s really useful.
So just to confirm, you mean that any power supply made for the 2007-2009 Intel iMac 24 inch will work fine, it’s just that the Apple product numbers and actual supplies may look a little different? Have I got that correct?
Thanks for your support.
If it’s helpful. This is my current faulty power supply. https://share.icloud.com/photos/0VsYhICk...
This is the replacement I’m looking at.
https://share.icloud.com/photos/0Np6SZk0...
Thank you.
As long as its a 250 Watt unit and has one of the Apple part numbers listed you'll be OK.
댓글 달기
귀하의 답변을 추가하세요
Sam Harries 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 246
