주요 콘텐츠로 건너뛰기
모델 A1369, 1.6, 1.7, or 1.8 GHz 프로세서, 64, 128 또는 256GB 플래시 저장공간
328 질문 전체 보기
Can I swap the screen from a 2015 MBA to a 2011 MBA?
I have a dead logic board MBA 2015 and a damaged lcd panel MBA 2011 (has a wide vertical line on the middle of screen and flickers if you move the top lid). So I was wondering if I can swap the full display assembly from the 2015 to the 2011.
Or If I can salvage the LCD panel from the 2015 and swap with it the one thats broken in the 2011 MBA (keeping all the same connectors, antennas, iSight.. just replacing the LCD)
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You can swap the display assembly if you’re ready to forget about your webcam, that doesn’t match by at all. You can remove and replace the panel if you wish so, they’re just the same, but it’s not an easy job, if you didn’t do it before there are pretty good chances you may end up damaging the Lcd and/or the backlight sheets.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Alejandro 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 28
