How does one fix a power window that does not go up or down
how does one repair a window that does not go up or down in 2005 equinox
좋은 질문 입니까?
좋은 질문 입니까?
The motor that drives the window regulator may be faulty. Or the switch may be bad. You’ll need to pull the door interior off and explore the window motor wiring harness for proper voltage and operation from the switch. If this is a rear window, make sure the lockout switch on the drivers door isn’t engaged. Most new cars have that and it always get inadvertently overlooked and engaged.
해당 답변은 도움이 되었습니까?
It’s often broken wires between the door and post. Open the door, and pull back the boot surrounding the wires.
해당 답변은 도움이 되었습니까?
I am dealing with a 2012 that has no power to window motor but power to door lock and radio sends sound to door speaker
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 1,351
Do you hear a motor spinning or any other noise when you toggle the switch ?
Vertinhol 의
