주요 콘텐츠로 건너뛰기
Samsung Galaxy S9은 모델 번호: SM-G960XU로 식별됩니다. 2018년 3월에 출시된 9세대 Samsung Galaxy Series 입니다. 색상은 라일락 퍼플, 미드나잇 블랙 및 코랄 블루가 있습니다.
137 질문 전체 보기
Why my screen turned black?
So my phone fell, and the entire screen went black.
At first it was a crack, the next day the bottom half was flashing and couldn't see the bottom of my screen but this awfully strong flashing light. Then two days later it went black, and couldn't hear my phone ring or anything even tho I had charged for couple days but then I tried rebooting it (power button with lower voice button) and I will only see a thin line in the middle of the screen!
What needs to be fixed or replaced?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
I did it just won't turn on the whole screen only a straight line because of the crack:(
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
The screen needs to be replaced.
A local reputable repair store or an authorized Samsung Service Center (SSC) can replace the screen for you. Prices may be similar from both stores so if they are go for SSC if it is.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Most of the times this kind things happened (i mean wont responsive) because firmware crashes. You should check the Galaxy S9 troubleshooting page because there can be solution for your problem. Have you try to force restart it while connecting to the charger?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Mrs. Allabani 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 16
전체 시간: 1,637
