주요 콘텐츠로 건너뛰기
Scientific calculator by Casio with 252 functions and full dot matrix display. It also features a Replay function and seven variable memory.
repairing of shift button in calculator
how to repair shift button in calculator
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
What's wrong with it? Not working at all? Did you spill anything on it? Did you open the calculator up to look inside? Did you try to clean the contacts yet?
댓글 달기
답변 2개
  1. If you have had this calculator for some time it may be a hardware problem where there is a bit of graphite from the button on the board stopping it from receiving the input carefully clean if it comes apart or use contact cleaner.
  2. If it is a multi function calculator try going through the modes and get to to RAD or check the second function priorities. If none of that works hard reboot by taking out the battery.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
সুইচ কাজ করছে না
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Hasnain Ahmed 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 32
전체 시간: 3,461
