Laptop won’t start up.
When I try to start up my Mac the sleep light comes on for a couple seconds, turns off for about the same amount of time, then turns back on again permanently. The screen doesn’t do anything, no startup chime.
좋은 질문 입니까?
좋은 질문 입니까?
I had bought a used for parts duplicate of this laptop and swapped the mother boards out. The problem is now fixed
해당 답변은 도움이 되었습니까?
If you haven’t replaced the battery that is where I would start as its likely long worn-out even if you leave it plugged in all of the time.
The front white LED is sleep indicator light (SIL) here’s a bit more on it Mac computer Sleep Indicator Light behavior.
The system will also go into sleep when its not getting enough power from either the charger or battery. If the MagSafe plug is Green and flashes five times when starting up or after waking from sleep then the battery is in need of replacement for sure. Amber implies the battery is in need a charge and if it never gets to green then that too implies the need for a new battery as well.
해당 답변은 도움이 되었습니까?
The charger doesn’t do any of that, the battery is still like new in the laptop. But I did end up fixing it thanks.
24 시간 전: 0
7일 전: 5
30일 전: 8
전체 시간: 147
댓글 1개
Wow! I'm amazed on how pristine it looks! I don't see any signs of wear given its a 10 or so year old system!
Dan 의
