주요 콘텐츠로 건너뛰기
The TI-89 Titanium is a graphing calculator developed by Texas Instruments (TI) and released in 2004. TI-89 calculators include a computer algebra system that allows the symbolic manipulation of algebraic expressions.
3 질문 전체 보기
missing horizontal pixels on display screen
I have two missing horizontal lines of pixels. The first is just below the tool bar and the second is almost half way down the screen. I ran the self test for the calculator and confirmed that the lines were missing. Is this a hardware problem or software problem. How can I determine which it is. If it is a software problem will a reset fix it without removing the factory installed programs. But if it is a hardware problem would this be an easy fix.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi this sounds like a hardware problem. Unfortunately, unlike the TI 83 and TI 84 lineup, the TI 89 ti doesn’t have a standard ribbon cable you can fix, instead TI attached everything to one piece making it nearly impossible to fix yourself. Even the most skilled calculator enthusiasts I know haven’t been able to repair a TI 89 ti display. :(
I’m sorry I wasn’t able to help you repair it, however if you have any other questions I’ll be happy to answer them.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
https://www.cemetech.net/forum/viewtopic...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Lawrence Dunbar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 25
전체 시간: 1,273
