Why won’t my Hamilton Beach 12-Cup Coffee Maker dispense anymore?
My coffee maker will not dispense coffee anymore, everything else works at this point, just nothing comes out when I press the trigger to dispense the coffee. Is the button that initiates dispense coffee replaceable or should I just repurchase a new unit? Please help?
좋은 질문 입니까?
댓글 8개
I noticed there is a small plastic extension on top of the trigger that activates the dispenser when the trigger is pressed. The plastic extension becomes weak and just bends when the trigger is pushed and does not put any force on the dispenser and it won't open to let the coffee out.
D H 의
Is there a fix?
susansrealestate 의
take it apart and clean it. The rubber part may have been popped out of place. there are a couple screws underneath you can remove and the assembly can be taken apart, cleaned, and reassembled. Don't lose the spring!
Jason Kelley 의
Can’t get it apart after removing the 2 screws.
Keith Enderson 의
Wrong bottom, not the machine but the removable canister
Keith Enderson 의
댓글 3개 더보기
