주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
Why does my replacement screen have artifacts?
I purchased and installed a replacement screen from iFixit. All was well for several months, then it started having these strange artifacts. The top of the screen image becomes interlaced with the bottom third of the display. It seems to be connected with the display brightness, as well. The artifacting is worse at higher brightness settings. I tried emailing iFixit support two or three different times, but they never replied to me.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
You should replace the screen,
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
This was already a replaced screen. I'm trying to figure out the cause. Could it be a bad connector or wire? I don't want to replace the screen if that's not the problem.
댓글 달기
Hi Jake
Looks like you have an issue with the LCD connection. You could try to reconnect the cables to the logic board but this issue is most likely a loose connection between the cable and the LCD panel itself. I would recommend a replacement screen.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jake Rhoda 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 25
전체 시간: 554
