Screws stuck in motherboard
I can’t remove the screws from the motherboard of the DS, and they’ve started to strip. Anybody have any tips that I can try? I’ve already attempted the rubber band technique, and it hasn’t worked out.
좋은 질문 입니까?
좋은 질문 입니까?
Hi Vishal
One trick I used to use when stripping small screws is to carve a straight line into the top and take it out with a flat-head screw driver. you can use any Dremel kit with a pointy bit to carve your line or just grind the top totally off. Here’s a cheap one from harbor freight tools:
https://www.harborfreight.com/Rotary-Too...
Best of luck!
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 88
