주요 콘텐츠로 건너뛰기
iMac G4에 대한 수리 정보.
130 질문 전체 보기
finder folder and question mark
When I turn on my computer, I get the green/gray screen with the finder folder and a question mark after it. That's all it does. I try to hold the mouse button and boot, nothing. I try to hold the c key and boot and nothing.
Anyone had an idea of what's going on with my imac. It was given to me. It's a 700 mhz, 128 ram and a 40 GB HD.
Thanks....
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
Your machine can't find a system folder. Either your system is corrupted or your hard drive has gone bad. Start up from your system installation DVD by inserting the disk and holding down the "C" key on startup. Go to the second screen pull down menu to Utilities > Disk Utility. See if the drive shows up on the left. If so click on it and run repair till it runs clear. If it does not show up, it has gone south and you will need to replace the drive with a new IDE drive and install a new system.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
How can I open the cd tray? I've tried ejecting it with the keyboard and no luck. Is there any other way to eject the cd?
Try holding down the mouse button while starting up.
I tried that also and nothing pops out. I don't think the cd tray works at all. At this point, since it needs a new hard drive and a cd tray, is it worth fixing?
You'll spend about $70 on parts. If you don't have a system installation disk you'll have to buy that too. A kid would love this machine.
댓글 달기
귀하의 답변을 추가하세요
Francisco Abrego 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 2,011
