The laptop only gets on for two minutes?
after switching on the laptop it gets power off after 2 minutes. and have to wait for 30 min to switch it on again.
좋은 질문 입니까?
좋은 질문 입니까?
This could be overheating, does the laptop get excessively hot? If so, open it up, and try and clean as much dirt/dust out of it as you can. Dust builds up inside of computers over time, and can clog vents, fans, and heatsinks inside of the computer, causing it to heat up. Clean out the fans and heatsinks, then try it out. If it is still acting up, the battery may be to blame. You can get a replacement battery on eBay for around $25.
해당 답변은 도움이 되었습니까?
+ totally agree. Just in case you need the service manual, it is available at http://h10032.www1.hp.com/ctg/Manual/c00... Good Luck
+ also consider replacing the thermal paste
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 1,861
