usb dissconnect high power device
SONY BRAVIA KD55EX7073SU
Keeps showing High power device please disconnect USB showing bottom right even with nothing at all connected at all
좋은 질문 입니까?
좋은 질문 입니까?
weird, in case you haven’t disconnect the power and press the power button on the right back (if it’s like mine) to make sure it’s drained and plug back in. you could also try cleaning the USB port with something wood or plastic such as a tooth pick, and also update the firmware which can be done via wifi I think around the device info or support section in the settings.
해당 답변은 도움이 되었습니까?
Tried all that no change tv still the same thanks
Wait for some several minutes then press home button or ok button to solve it ……thanks me later ?
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 8,833
Sony LED TV high power device please disconnect
Vishnu 의
Sony LED TV high power device please disconnect USB
Vishnu 의
My Sony Led modal no KLV28R412B IS PROBLEM SCREEN SO HIGH POWER DEVICE PLEASE DISCONNECT USB
SUNIL KUMAR 의
Sony Bravia showing high power device please disconnect usb but no usb connected
Vinay Dongre 의
I have just bought led strip lights for my Sony bravia TV. TV keeps saying
High powered device. Please disconnect USB.
Is there any way to stop this pop up on screen as its to big and distracting.
Peter Spanner 의
댓글 2개 더보기
