주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1863, A1905. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
3d touch doesn't respond
Replaced the iphone 8 screen and 3d touch is totally unresponsive. Took the screen back off, checked all the connections, and it still won’t respond. Also tired adjusting the 3d touch settings, and a hard phone reset, but nothing helps! Any suggestions?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
Try putting your old screen back on. If it works then at you need is a new screen
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Could be the quality of the new screen. Where did you get it from? If it’s a cheap screen off of Amazon there’s no telling what you may get in terms of quality. Did you check all the cables? Make sure nothing is pinched or that any pins got bent. Apple could have also just decided to disable this feature with a software update if it detects a non genuine Apple screen. Doubt that’s the issue but with Apple you never know.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Josh Hixson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 79
