주요 콘텐츠로 건너뛰기
블루투스를 사용하는 스마트 피트니스 워치, 2016년 3월에 출시되었습니다. 모델 : FB502SBUL
Why is my blaze on constant vibrate
My Blaze is constantly on vibrate. It happened in the middle of the night and will not stop.I put it on the charger and it is still vibrating
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
Alvaro, the Fitbit Community Manager, suggests performing these steps:
Try restarting your tracker by doing the following:
Press and hold the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen. This should take less than 10 seconds. Then, let go of the buttons.
If your tracker doesn’t work normally, turn off your tracker manually by performing these additional steps:
  1. Swipe right to left on the home screen to the Settings screen.
  2. Tap Settings and scroll down to Shutdown.
  3. Tap Shutdown and confirm.
  4. To turn your Blaze back on, press any button.
  5. Sync your tracker as soon as you turn it back on. If you don't, the time may be incorrect.
Try this 3 times in a row.
Also if you have any alarms please deactivate them and sync your tracker.
If that doesn’t fix the issue, then they ask that you contact Fitbit Support here.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Buttons aren’t working either. Worst watch ever.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Deb Robertson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 933
