주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
iPhone has IMEI but no service or modem firmware
Customer brought in an iPhone 7 with intel modem. iPhone has IMEI in the info screen but no modem formware. If I press *#06# it doesn’t show IMEI.
There is almost no information about Intel baseband issues and the lines also have different names. Any advice or tips for this problem? I measured the surrounding capacitors and found no short.
Update (08/30/2019)
Reballing the BBCPU did the trick.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
This would defiantly be a baseband issue although the Intel versions don’t usually suffer from this problem unless someone has replaced the audio IC and put too much heat on the board causing solder bridges under the baseband CPU.
ZXW has a comprehensive board view for the Intel now. I am not sure what lines you checked but I would start at the baseband PMU and then to the baseband CPU. If nothing rears its head I would replace the baseband PMU if that didn’t resolve it a reball of the baseband CPU would be the only other thing to try.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Replaced BB pmu already but nothing. iPhone has never been repaired before. Will try to resolder the BB CPU
댓글 달기
귀하의 답변을 추가하세요
KWH 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 2,395
