주요 콘텐츠로 건너뛰기
Apple의 올인원 데스크탑 컴퓨터. 2006년부터 2011년까지 인텔 프로세서가 탑재된 iMac.
7455 질문 전체 보기
Will Macs upgraded to Core2Duo Processors work with Lion?
I have upgraded a couple of 1.83 GHz iMacs from Core Duo processors to 2.16 GHz Core2Duo processors in the hope of being able to install Lion on them. The "about this Mac" shows that the CPUs are seen and x-bench shows the greatly improved machine. I tried installing Lion and it tells me these machine cannot load it. Does anyone know what to do? Is this a ROM problem?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 2개
I'm using a paid version of Lion. I cloned via Target Mode, removed the plist and tried to boot. Got the Apple and spinning disk. After a couple of minutes of getting no where I rebooted in Safe Mode and got a start after it did what looked like a rebuild. The startup is very slow but it finally came up. It still thinks it's a MBP in the upper right hand corner. About this Mac shows the 10.7. Software update ran with no updates. I'm running 1.5 GIGs of RAM. Will run x-bench tomorrow and see how it compares to the 10.6.8 run. It seems slow. I could not get the Command R boot to work. Will keep you updated on my progress.
xbench was actually a little better
댓글 달기
답변 2개
선택된 답변
From what I understand, the Lion installer checks the system model, and goes from there. For example, the Lion installer would see "MacBook1,1" as the system model in my computer, and know that that is a Core Duo based computer, and not allow installation to procede. There is a method to install Lion (At least the developer betas) on a Core Solo/Duo machine, where you install Lion via Target Disk Mode, using a Core 2 Duo+ machine, and then edit a system file on the newly installed OS. Lion will then run on Core Solo/Duo. I know that the developer betas of Lion can run (But by default, aren't allowed) on 32-bit architecture. Installing Lion on an upgraded machine should be possible through the same method, and the extra modification may not even be necessary. Here is an article highlighting the process.
해당 답변은 도움이 되었습니까?
점수 5
댓글 3개:
So if I use SuperDuper and clone my MBP 2.5 installation, then change the line while still in Target Mode it will work. Great solution Chris, Thanks. I've renewed my developer status so I can get betas again. There's just to much to learn in one day.
Great answer!!
Cloning the hard drives should work, I'm not sure if the developer betas expire or not, I actually got them from a friend. You may not be able to use them forever.
댓글 달기
There's an app for people in this situation - written by me :-)
It works with all versions of Lion from DP3 upwards including the current domestic version on the App store so theres no need for a developer account
http://www.insanelymac.com/forum/index.p...
해당 답변은 도움이 되었습니까?
점수 5
댓글 2개:
Great work. That'll help many-many people.
+ sounds good, will give it a try on the Command R
댓글 달기
귀하의 답변을 추가하세요
mayer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 3,248
