주요 콘텐츠로 건너뛰기
The Epson Artisan 1430 is a color inkjet photo printer.
paper and ink lights both flash together
My EPSON 1430 ‘s paper and ink lights flash on and off in sync with each other and I can’t do any printing. I am not getting any on-screen error messages so not sure how to fix this error condition
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 4개
선택된 해법
Look in Owners manual. Can find on line. It will say that this means the ink pads are full and the printer is at end of service life and to contact Epson. They will tell you to buy a new printer. Go to Youtube and search for “reset Artisan 1430”. You will find info on resetting lights and installing a waste ink tank. Sort of designed obsolescence I think.
Update: found service manual with details on waste ink pad replacement:https://www.4shared.com/archive/Cm2eWu2p...
Waste tank install is probably easier and better long term. than messy pad replacement.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
Another trick...before turning it on, open the upper paper tray (see pic), then close it after printer starts up. This seems to stop the 2 light blinking problem. I don't know why.
This has been working for me for 2 years
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
This fixed it. Presto!
fixed for me too... ta ta
Epson SC-P400 printer
I was very skeptical. I had followed the Epson instructions to a "t" and reinstalled software, etc. Still had simultaneous flashing paper & ink lights.
I tried the suggestion here of opening drawer (?) before powering up. Then closed it after power up.
SUCCESS!!!!
Thank you very much. I'm back in the printing business (not really business...but a common saying).
Thanks again.
댓글 달기
Hi Roderick !
Research I just did.
This would be a problem with the printer's stamps:
Explanation of LED error codes available here.
There's this video that explains how to solve the anomaly.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Blow out the paper feed area with a can of compressed air. This fixed mine after I was in panic mode.
There must have been dust or some small, unseen debris setting the sensor off. Hope this works for you.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Thin strip of paper appeared when I gave a little blast and BOOM, back in business!
This was also my problem - just a little scrap of paper was stuck!
amazing.. thanks so much!
댓글 달기
답변을 추가하세요
Roderick Salter 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 8
지난 7일: 35
지난 30일: 169
전체 시간: 13,951
