주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
Internal microphone recognized, but no sound input
I have a 13” Mid-2012 MacBook Pro (MD101LL)
The internal microphone is shown in prefs but non-functional. Built-in internal speaker works fine, iSight camera video works fine.
Not sure if software or hardware issue - no issues found with Apple diagnostic test. Here are some screenshots:
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
Well as you didn't post any graphic of the input volume setting for the mike, I have to ask if the microphone input level is turned up high enough and/or if there is a mute function on that computer for the microphone? Wouldn't be the first time I've seen that kind of omission. :-)
No sound input even when input volume is maxed. Same with ambient noise reduction on or off. No mute option shown for the internal mic in system prefs or anywhere else I can see.
ZT, why do you think the mic input isn’t working? What are the observed symptoms? (May seem like a strange question, but could be important to troubleshooting.)
댓글 달기
답변 1개
가장 유용한 답변
Been there, done that. Did you open the system and not remove the LVDS bracket thinking it’s optional? That will do it.
It’s best to replace the mic after this error since the wires will never be secure again as there is no tolerance to replace the connectors and you will probably break them if you lift it up for some retention (and ruin the mic). If you can reinstall the wires and keep them in with some confidence it won’t happen again easily, you may be able to rewire the mic and save your money. To do this, it’s best if you have the original Apple tape to reduce the chances of the mic failing without warning again. Eventually it’ll happen again, so if you run into an issue again remember to check the mic first. If you depend on it, replace it so you know it will not be an issue going forward.
Also if you take this to a repair shop please warn them you rewired it to save the mic so they know they need to be careful with the microphone you broke. Don't try and hide it.
Reference this photo for the rewiring:
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
ztwrigh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 11
전체 시간: 249
