주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
I changed a battery for a customer. screen touches by itself.
So I replaced a battery for a client of mine.
after that she came back (after about 3 weeks). The screen clicks by itself.
From what I know a battery replacement should not do this to a phone, anyone know of a solution?
I did replace the battery three days ago again, since I thought maybe there was a bad battery, she came back now. Same issue.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I believe that would be a bad digitizer module or connection. Try reconnecting the display, then switching displays (if you have a spare).
An iPad I once fixed was worse. When you had the keyboard up it would type random things, even when you leave it alone in a room with no one else. It was like a ghost possessed it.
Good luck!
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I have a battery stand, the customer said she changed screen at someones home before that, so it was solved with a new screen.
댓글 달기
귀하의 답변을 추가하세요
nicolay.94 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 45
