주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
904 질문 전체 보기
[SOLVED] iPod Classic with SD Card is Crashing, Freezing, and More
Hi,
I have an iPod Classic 6th Generation 80GB, which was upgraded to work with a micro SD card. I am using an iFlash Solo board with a 64GB SanDisk Ultra Micro SD card (Recommended on iFlash.xyz). The iPod works fine for a while, but then it begins to act up.
I restored the device through iTunes and installed the latest OS software. It works fine until a couple of songs later, which is when it starts to act up. It begins to stop playing songs (but I can still hear the iconic click wheel sound), skip tracks, restart automatically, freeze on boot up, flash the apple logo, then repeat. I did a hard reset, restored it on DFU mode, and no luck.
After restoring the iPod for the 2nd time and still experiencing the same issues, I decided to install Rockbox into the device. I understand that Rockbox has an unstable version for iPod Classic 6th generations, but I don’t have any other choice? Well, it worked longer, but it then crashed multiple times and freeze on boot up. Once again, I reinstalled Rockbox and, sadly, it didn’t work.
At this point, I’m starting to believe that the problem is my SD card. I bought mine at BestBuy, and it works fine on my phone. On my phone, I am able to transfer songs and play them without any problems.
I have looked up for solutions online, but nothing seems to have a long term fix for my iPod. I already tried tt2 (https://discussions.apple.com/thread/502...), and it still didn’t work for me.
I have tried fixing my iPod on a Mac and Windows with a formatted SD card of FAT32 and Extended Journal. Any help is greatly appreciated!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
iPod Classic had an incompatible micro SD card. It is now fixed.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
When you say 'incompatible' what do you mean? What did you change?
@Jim I used a SanDisk Ultra Plus micro SD card, instead of SanDisk Ultra. iFlash.xyz provides a list of compatible SD cards for each of their boards.
댓글 달기
귀하의 답변을 추가하세요
Anthony Zamora 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 12
30일 전: 50
전체 시간: 1,886
