Beeping problem every time when booting
I recently bought this computer used and everytime I turn on an start up it starts continuously beeping until it finishes booting up. I was wondering if there is a way to stop this beeping
좋은 질문 입니까?
점수
0
댓글 2개
Oh i forgot to mention what kind of computer it is. Its a HP z400 with intel xeon w3565 cpu 2x4gb and a Samsung ssd 850 evo
Ivan Phong 의
Probably error codes. First thing to try though is log into the BIOS and if the settings look OK press the F10 key to save the settings and reboot the computer. If the computer was just complaining about the correct settings not being saved, the computer should reboot without any further beeping. It may also be a case that the CMOS battery (typically a 2032 iirc) is dead and needs replacing. Check your owners manual for the location of the battery holder on the mother board or open up the computer case for a look. If you take the battery out of it's holder, you can check the voltage with a multimeter; again check your owners manual for correct battery levels. If beeping persists after that then it's time to Google for relevant error codes or again check you owners manual which may also contain that information.
prop man 의
