주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple은 2015년 3월 9일에 Retina MacBook 2015 모델 A1534를 4월 10일에 출시한다고 발표하였습니다. 새로운 유니바디 구조 및 업데이트 된 트랙 패드, 키보드, 그리고 Retina 화면을 포함합니다.
Random screen flicker 2015 MacBook
I was using my MacBook the other night when the screen started to flicker.
I tried the usual suggested resets, turning it off and on etc but nothing really budged, so I left it it a few hours and it was fine to use for a day or two until tonight when it started flickering again.
Dreading the bill to repair it!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Most of the time resetting the PRAM will solve this issue:
  1. Shut down your Mac.
  2. Locate the following keys on the keyboard: Command (⌘), Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Hold Down the keys
  4. While holding the keys, press the power button. Technically you don’t need to press them until it turns on, but you need to beat the gray screen, so it will be easier for you to just hold them down from the start. Keep holding.
  5. Hold the keys down until the computer restarts and you hear the startup sound (Chime) for the second time.
  6. Release the keys. Your mac is going to start up normally, and most likely the problem will be solved.
이 답변이 도움이 되었나요?
점수 1
댓글 6개:
Unfortunately not, I’ve tried this and the SCM reset.
When this starts are you going to things that may engage the graphics chip. like YouTube? It could be the switching from integrated to discrete graphics card or graphics card failure?
Begins on startup, the Apple logo will have a vertical band through it.
Try starting in Safe Mode by holding down the Shift key on startup to verify this is not a software problem.
Still flickering in safe mode
댓글 1개 더보기
댓글 달기
답변을 추가하세요
Joe Kerslake 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 501
