주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 더 큰 Apple MacBook Air 노트북 입니다.
465 질문 전체 보기
MacBook Air Shuts off at 75% power, Service Battery Warning
When I have my MacBook Air 13” (mid-2013) it will randomly shut off about 75%. The battery icon says service and I’ve attached the Coconut Battery screenshot. I know it’s a several years old at this point so if I need to replace, just let me know.
Thanks for the help!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Service batteries may show all sorts of issues, including sudden shutdowns especially when peak power is required by the system. A replacement would probably be all you need and surely the first step to take in this case.
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
An easy repair! MacBook Air 13" Mid 2013 배터리 교체
While you haven't maxed the battery out from cycles your charging habits is likely the reason the battery prematurely died. Try to charge the battery before its dropped below 30%, waiting for it to drop below 15% will wear-out the battery sooner.
댓글 달기
귀하의 답변을 추가하세요
Jared 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 154
