주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1199 질문 전체 보기
iPhone fell and screen has light green lines
Dropped my phone on the floor it feel on the side screen has a tiny black dot on the bottom left and green lines going down the phone where can I fix it an how much
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
it will likely need an lcd assembly replacement. you can always try this yourself and source the parts, however it’s not something I’d necessarily recommend for a first repair attempt since it’s very easy to break the face id cable on the screen on these ones. if you go this route I’m sure there’s a guide on ifixit for it and I’d definitely follow it closely.
otherwise you’ll want to try to find a reputable repair shop that can repair it for you and get a price quote
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Just before you order a new screen, open the phone and check that all the cables are firmly attached. There’s no harm in checking and it could save you time and money. Only then should you replace the screen
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
How much does this repair cost and where can you take it to get it repaired?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
mina_khan786 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 14
전체 시간: 6,991
