이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
If you don't hear the motor rev'ing up when you step on the gas pedal, then the linkage between the pedal and the motor is malfunctioning. Something broken, or loose probably. Will need to trace the linkage to determine the problem.
Have you checked the throttle linkage/throttle system? Since it’s idling even with the pedal down, surely something’s wrong. Just make sure to turn off the engine before you check.
prop man 의
