주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.0GHz, 2.3GHz, 또는 2.6GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.8GHz).
580 질문 전체 보기
Where to buy display assembly or how to replace internal LCD panel?
iFixit hasn’t had any reasonably priced display assemblies for this model for years — when they had any at all…
  • Where can we source the LCD panel itself, rather than the much more rare assembly?
  • If we were to find the LCD panel — how might one do the swap/repair?
  • Lastly: I doubt there are any good answers (beyond “watch the ‘used’ markets) but where else might have legit/oem displays to purchase?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
You won’t find the LCD panel for this display or instructions on how to disassemble it, because the display assembly is the LCD panel. The aluminum casing itself is the back casing of the LCD, and the front glass on the display is the LCD itself. Even iFixit couldn’t disassemble it much more than it already is without breaking the glass. You can learn more about how the panel is assembled and why you’re stuck with replacing the whole thing in their teardown guide: MacBook Pro Retina Display Teardown
The iFixit pricing is a little on the expensive side but I wouldn’t call it unreasonable. Personally I buy displays from ProTech (https://www.protechrestore.com/index.php...) but I’m sure there are many options available.
Basically, you’re stuck with buying the full assembly :)
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
LCD panel also needs programming if EDID code is not accepted by MacOS auto brightness won't work and brightness adjustment won't work. Yeah these screens from experience cost me like $600-$800 AUD.
댓글 달기
i’ve noticed a few used ones going for fairly cheap on ebay, not sure if they are any good but maybe a good place to find them.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
jasonbuechler 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 35
