주요 콘텐츠로 건너뛰기
Announced on July 2015, this is Motorola's flagship phone. It has a 21 mega pixel camera with a 5.7 inch IPS TFT LCD screen with a resolution of 1440 x 2560 making it Quad HD. Model number XT1570, XT1579, XT1575 and XT1578.
Device all of a sudden won't connect to cellular network?
I went through all of the troubleshooting with my phone service provider, they said it must be something with the device itself, and to contact Motorola. When I contacted Motorola they just said that my warranty was expired and I have to go to third-party repair. What could be wrong with my device? Is there anything I can try before taking it to be repaired? Thank you
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
Moto X Pure Edition Troubleshooting
Outdated Software
Make sure the system is up to date with the latest firmware and latest software. If this is out of date, it can cause connection issues because it is not the newest version. To check is the system is up to date, go to Settings>About Phone> System Updates.
And have you tried booting into Safe Mode (also taken from that same page):
To do this, hold the Power Key until Power Off shows up. Then tap OK when it asks for Reboot To Safe Mode. If you have no flicker when restarting then it is most likely because of an app you installed and you should try uninstalling them one by one.
Just a thought.
I will give that a try. Thank you!
Are you saying to check if it connects to the network in safe mode? Because it doesn't
댓글 달기
답변 1개
가장 유용한 답변
First, check that mobile data is turned on and you have a data connection.
  1. Open your Settings app "Wireless and Networks" or "Connections" Mobiledata or Cellular data. ...
  2. Turn mobile data on. ...
  3. Check that there is a data indicator (for example, 2G, 3G, 4G, H) next to the signal strength bars at the top of the screen .
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
With mobile data switched on, there are zero signal bars or data indicator
댓글 달기
답변을 추가하세요
Coyote B 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 1,468
