주요 콘텐츠로 건너뛰기
2011년 7월 21일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Thunderbolt. 이 기기는 Mac mini Server 구성을 실행하는데도 사용됩니다.
204 질문 전체 보기
Replacing broken Mac Mini mid 2011 logic board with Intel GPU version?
The discrete AMD Radeon 6630M GPU in my mid 2011 mac mini is stopping reboot. This issue seems to be common with this discrete graphics card. 2011 Mac mini GPU failed (Radeon 6630M) - repair options? mentions that swapping the logic board for less powerful one with integrated Intel HD Graphics 3000 works and would be more reliable. This seems attractive but I have 2 queries:
  1. Where do I purchase one of these - any advice? iFixit says out of stock and I haven’t managed to find one. I’m located in the UK so ideally somewhere UK based that doesn’t charge the earth for deivery would be preferable.
  2. Would it run Adobe CS6 ok? From my research Adobe recommends 500MB GPU RAM. I’m not sure now this works but my Mac Mini has 8GB of CPU RAM so if it takes it from this then sounds like it would be ok. Anyone know?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Well, you’re in luck! Liverpool UK has one of the better Mac parts sources! Take a look here Logic boards for Apple Mac Mini Mid 2011
As far as running CS6 on an intergraded graphics engine of a 2011 Mac Mini, thats a bit iffy… Small jobs won't be a big issue but as you get into bigger more complex image or video creations you’ll hit the limitations of the CPU and graphics services the given system has.
If you are planning on doing a lot of heavy stuff I would recommend getting a more powerful model. Give this a read EveryMac - Mac Mini Q&A. Ideally you want an i7 CPU and at a minimum the Intel HD Graphics 4000.
If you stick with the direct replacement logic board I would recommend getting a good thermal management app like TG Pro so you can better cool your system and monitor its thermals more effectively. You may need to be more aggressive in cleaning it of dust and making sure the vents are not blocked.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thanks Dan, that's very helpful.
Do you know if I can slot in an i7 logic board with Intel HD Graphics 4000 into my mid 2011 mac?
I'm not sure if a 2012 logic board will fit into a 2011 case. I've not tried doing it.
댓글 달기
귀하의 답변을 추가하세요
Justin RW 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 899
