주요 콘텐츠로 건너뛰기
2018년 10월 26일 출시. Models A1984, A2105, A2106, A2108. GSM 또는 CDMA / eSIM, nano-SIM 또는 dual-SIM / 64, 128, 또는 256GB / 검정색, 흰색, 파란색, 노란색, 산호색, 또는 빨간색. ("iPhone 10 R"로 발음합니다.)
468 질문 전체 보기
iPhone xr lcd screen?
I bought a xr from a repo company but there is no lcd with it just the base of the phone works perfect seen in itunes.
But id like to know what problems I could run into when I put a screen back on it I plan buying a full transplant from a iclocked on of ebay will face id and front camera still work as bear in mind ive no screen or parts ?
thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Anything or nothing. Really no way to tell without trying.
댓글 달기
답변 2개
가장 유용한 답변
I'm pretty sure the face iD will not work , unless it's the original screen.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
If you buy a screen that was formerly iCloud locked, it won’t make no difference to the screen. Only difference is the device itself it WAS iCloud locked. So yes, you can take a LCD screen off an iCloud-locked device, since it only effects the logic board INSIDE the phone, all the other parts won’t be effected. So everything else can be tested like it should, though i’m not sure if Face ID will work as it is from a difference phone, but it is worth trying if that’s what your curious about.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
sam M 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 166
