주요 콘텐츠로 건너뛰기
Released on February 2016, The Asus Chromebook C202 is a ruggedized device created with students in mind. It is a small laptop that can handle minor spills and drops.
17 질문 전체 보기
Why is my chromebook not turning on?
After using, I closed cover—next time I opened it, it would not turn on, with or without power cord plugged in, and no (charging indicator) lights come on when it is plugged in. Battery had plenty of charge when I closed it down.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
It appears from the following that the unit can be booted minus the battery being hooked up. To eliminate the battery as a potential source for the non-booting problem, I suggest you disconnect the battery and try booting the unit again.
Why is the computer not charging or booting? Battery removal works..
For further information and tutorials (including removing the battery) see:
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
K Einspahr 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 12
전체 시간: 230
