주요 콘텐츠로 건너뛰기
The 7" version of Amazon's new high-end tablet series, released in October, 2013. Model C9R6QM.
55 질문 전체 보기
do I need an adhesive replacement
The Kindle HDX 7” uses adhesive to glue down the battery and the plastic upper bezel over the volume buttons and speakers. Once I remove that adhesive, what do I replace it with, or is it even necessary?
Thank you in advance for all help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
crtrue, Steven Inman - Thank you both! Re-adhesion wasn’t touched upon in any guide I could find. Red tape seems to be the way to go here. crtrue, thanks for telling me the keywords!
댓글 달기
답변 2개
가장 유용한 답변
Batteries should be adhered in some fashion to prevent them from jostling around inside the device and disconnecting their cables or, worse yet, damaging another part of the device. I'm not entirely sure about the bevel but if it was originally adhered, you'll want to try and get it back on in a similar fashion.
As for the adhesive, you have a few options. You can buy some jewelry glue like B-7000 and carefully apply it to the components that need to be adhered and just let it cure. Alternatively, you can use “the red tape" and just cut it to size (look on Amazon for “phone red tape" and find one about the thickness you need).
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
i would definitely use “the red tape” on a battery as well just to make sure you don’t end up with a battery cable or connector ripped off.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Conductor 37 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 5
30일 전: 13
전체 시간: 231
