주요 콘텐츠로 건너뛰기
Released July 12, 2002. Identified by model number K45SSWH.
33 질문 전체 보기
Will not start on low speeds
My 32 year old KitchenAid Mixer Model K45SS (no WH at the end) will not start until I move the speed lever to at least 5 (that gets messy!). I can then move the lever back to the lower speeds and it will work fine.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
User Manual which contains information on toll free phone number for USA only (probably only for information on nearest service center and after 32 years more than likely out of date)
https://www.manualslib.com/download/1078...
That and done, your unit needs servicing. If doing the repairs yourself, open up the unit and do a visual inspection of the speed switch along with continuity and voltage testing using a multimeter. More than likely it will need replacing.
댓글 달기
답변 2개
Replace the Speed Control. Here’s the part:
KitchenAid Speed Control WPW10119326
This part fits model K45SS
https://www.kitchenaidparts.com/PartDeta...
Here’s a video on how to do it.
https://www.youtube.com/watch?v=HMRqoz3y...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My KitchenAid Model No K45SSWH stoped will It was working, when I open the back play I found a loose pice that look as a square U with a ceramic cylinder. I imagine that I have to replace the control plate and find if I need that pice? Please let me know what part to buy
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
please correct: should say Stoped while and the back plate instad of play
댓글 달기
귀하의 답변을 추가하세요
Mary Boudette 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 11
30일 전: 40
전체 시간: 6,086
