주요 콘텐츠로 건너뛰기
8.9" or 10.2" LED-backlit display, 1.6GHz Intel Atom N270, released October 29, 2008.
How do I fix a noisy hp mini 1000?
Noisy hp mini 1000
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
It's now 5:22 pm EST. I'll be away from system until after 8:30 pm. Will check upon return.
Jim
Should I decide to remover cover and replace/clearn motor is the availability of a spudger critical? What can be used in its place?
What exactly do you mean by noisy? Like the fan is blowing a lot? Or the hard drive is spinning really fast?
댓글 달기
답변 1개
선택된 해법
I just took one of these apart and they are quite easy to take apart. I would open it and inspect it further. This machine has a tiny fan with huge vents that facilitate dust and debris from getting into the fan and its chamber. Get in there with a can of compressed air clean things up. If it's your HD (the only other moving component) then I suggest you back-up and get a new HD as soon as possible. But, I'm leaning to the fan as the culprit for the noise.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
+1 and just in case you need the service manual, it is available at http://h10032.www1.hp.com/ctg/Manual/c01... and will show you how to deal with the guts of your machine...:-)
A Windows question for you--good answer. +
Thanks guys.
댓글 달기
답변을 추가하세요
Jim Edwards 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 2,749
