How can I fix a stuck up mirror?
My Nikon D5200 when open, an error appears on the monitor and it says Press shutter release button again.
When you click the shutter botton the mirror inside is not functioning well as in a normal way as in… its running halfway or not in full swing.
I notice it last time that I cover a birthday party I had a low-bat situation so I charge the battery and during the charging it happens there’s a brown out so the power went off then a few seconds the power goes back from a power generator and maybe 15 mins. later the power goes back from the main but still the battery charger was not remove from the outlet after 30 mins of charging maybe 1/4 of the battery was fill I continued to take photos.
I found out that when I click the shutter a time the flash doesn’t function later the mirror comes a halfway and seems dragging then when I check it a notification appears on the screen that I have to Press the shutter button again then it goes back but as time passes later I can’t take any pictures anymore.
When the event ends I went home and fully charge my battery for almost 3 hours then check it with my camera but still the same thing goes. My plan is to send it to the service center but before doing it I rely on this page whether you can fixed it before I do sending it to the service center.
좋은 질문 입니까?
