주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
Screen (bottom right) gets little dark after replacing the lcd
Hello everyone, I just replaced the LCD for iPhone 7 Plus and tested. When I turned on, the screen (right bottom side) got dark…what are the potential reasons for this…?
i don’t think I damaged any parts while replacing and I have never had this issue before while working on other phones.
Just in case, I used an extra LCD screen for this but the result was the same…so I don’t think it’s because of the bad lcd screen…
thank you for your time!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Check your display connector for any damage or dirt
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
I don’t think that display connector is the issue as I tried 3 new lcd and all of them showed the same problem. But I have no idea if the board has the issue or not..
did you check them ?? You are putting all the screens on the same connector so if ?? the connector was damaged in some way then all the screens would ack the same??
댓글 달기
check first dirt/debris in the connectors. if everything is clean and no damage it may be a board issue. test with the original screen if you can and see if it happens. if original screen lcd was damaged/non functional then it may be safe to say it’s a board issue, though you could probably try 1 more screen just to be safe.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you for your advise. The original lcd is damaged bad and cracked. Basically I can’t see anything from the original one. I posted the picture of the connector on the board just in case here. Could you see if any damages? I don’t really see any dirt or debris..
댓글 달기
귀하의 답변을 추가하세요
Alltech 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 6
전체 시간: 124
