주요 콘텐츠로 건너뛰기
The Chevrolet Silverado is a line of trucks under the Chevrolet brand and manufactured by General Motors. Mechanically, the GMC Sierra and Chevrolet Silverado are identical.
28 질문 전체 보기
Column Shift lever moves freely but does not engage gears
As I was parking my truck earlier I pulled up and quickly put it into park and turn off the key. What I noticed was while turning it off, the vehicle never made it to Park. The shift indicator is located in reverse however I cannot engage the shifter into any gears to move it into Park. At this time, I cannot start the vehicle as it will not enter neutral or Park. I've seen videos on older models needing a solenoid replacement got.. Anyone know if that's the case here?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
From my experience with this issue I would say that the shifting linkage has become disconnected at the transmission.
The best thing to do is have it checked by a certified GM Mechanic.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If you want to fix it yourself then buy the top and bottom part of the shift cable and I will be !&&* but if can replace it. I'm sitting in the parking lot right now doing this and got curious. Try to replace the whole cable and it will be fixed because if you buy another bushing then it will pop off 1month later and will soon do it every day.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
How hard was the replacing of the cable? Can it be done without jacking up the car?
댓글 달기
귀하의 답변을 추가하세요
bgtackle 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 14
7일 전: 88
30일 전: 352
전체 시간: 26,142
