주요 콘텐츠로 건너뛰기
A budget laptop that was manufactured in 2013 by Acer under the Aspire product line.
4 질문 전체 보기
Laptop not switching on
Hi
My laptop is not switching on, I have checked the power adapter and the battery and there are both working. I get the orange light when it's charging and I get the blue light when it's charged how ever when I switch it on nothing happens. What is the cause and how do I fix it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Re insert ram and HDD in your laptop this may fix your problem
댓글 달기
답변 1개
선택된 해법
Hi Shnisani,
for first, can you answer, how did it happen? Or, is there any helpful information which can help with the solution?
It’s look like BIOS stuck or just RAM bug, try:
  • Reset your bios using CMOS reset (disconnect power, battery and the small battery on the MB, if it’s model without battery on the MB, try to press the power button for about 30-60s and then it may be work - or pressing)
  • Unplug your RAMs and clean slot, then, insert only one (if you have more) and try to turn on, if nothing, select another slot
  • Disconnect your HDD and try to boot without it
  • Check cables from MB to display
It may be the only bug, but we need to know if the laptop is turning on without cooler start if the HDD is working while the laptop is about to start.
If nothing worked, write more description of your issue to comments.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Thank you
Lucas
i switched the Ram slot and removed the battery and the small battery on the MB then i press the power button for 30sec .
put everything back and when i put on power without the main battery, the LED light came on and i presspressed the power button and everything came on.
Thank you
Hi Shnisani, so well done! :) I'm happy that you have solved your issue.
Hi Lucas
My Acer Aspire ES 14 doesn't turn on with the battery on it and even without the battery, it still doesn't work. Please help me. Thank u!
댓글 달기
답변을 추가하세요
Shnisani Ranpfumedzi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 20
전체 시간: 1,937
