주요 콘텐츠로 건너뛰기
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
52 질문 전체 보기
SSD upgrade causes iMac 2015 to freeze after minutes of use
I upgrade my iMac to an SSD and once it boots up after minutes during use it will freeze completely and will not be responsive to anything. I have enabled TRIM settings but find that it is still doing the same thing. What comes next?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Can you tell us more details on which model iMac you have as well as the exact SSD you used (make, model and interface SATA or PCI).
댓글 달기
답변 1개
선택된 답변
Sorry actually I figured it out apparently I just needed to do a complete wipe of all data and reinstall the OS in recovery mode and now everything is good !
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Jerrell Jones 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 100
