주요 콘텐츠로 건너뛰기
Repair and disassembly guides for Kenmore Microwaves.
182 질문 전체 보기
No power getting to microwave.
microwave stopped operating and display went blank. Unable to get it to work. AC outlet is working fine,tried unplugging unit and re-plugging unit with no response,display totally blacked out, wondering if it's power cord,how can I evaluate this problem?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
you could check the fuses on the power cord..but even if they have blown I'd still throw this away... the fuse blew for a reason!
microwaves are cheap, and repairing them seems to be something that none of us here are willing to undertake....the risk to you is too great!
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
If you insist on working on this, take out a lot of life insurance. But that might nor work as it may be considered suicide, not accidental.
댓글 달기
If you have a bit of electrical know how, my dads microwave did the same thing and the fuses kept blowing. There is a power unit inside that had a 4 bridge rectifier. The rectifier is heavy duty and capable of carrying about 20 amps at 120 volts. Beware: there are also very large capacitors that can kill which remain charged even after the power has been disconnected.
To make a long story short, I bought a new (but different shape) rectifier and made a new mounting hole in the heat sink and ran some wires from it to the circuit board. To test the power supply check for continuity at the ac input terminals of the power supply. If shorted check the rectifier on the terminals marked ~. if shorted un-solder it from the board and find a replacement.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
James, I removed your email address. It will protect your privacy and will protect you from spambots. Do it like the rest of us and add it to your profile.
댓글 달기
귀하의 답변을 추가하세요
Warren 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 1,850
