주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Diagnosing iPhone 5s no power Diode Readings
I’m working on an iPhone 5s that randomly stopped powering on or charging. Ive done some resistance testing to look for shorts, but i dont have known good readings to compare.
Diode mode readings:
Vcc main 0.359
Pp5v0_usb 0.000/OL
Pp batt vcc conn 0.401
Pp1v8 0.410
Pp1v2sdram 0.271
Pp5v0 usb prot 0.556
Mic1 to codec p OL
Any ideas to lead me towards a solution? Does the pp5v0usb OL look important, i only see 3 caps next to the connector highlighted on that line in zxw?
Pp5v0 usb conn is ol, but im not sure this is significant. Pp5v0 usb prot was .556. Does anything beginning with pp5v0 lie on the same line? And what is pp5v0 as it relates to the operation of the phone?
The charging MOSFET Q4 had a few solder balls at the base of the underfill.
How would you proceed with testing voltages, especially around the charging circuit and maybe tristar to determine the issue?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
If you are just starting to diagnose phones, grab the schematics for the iPhone 5s look at the power management chip and trace where your pp5V lines go. I would suspect it is normal for Pp5v0 usb conn to be OL.
 I would start checking the readings at your charging dock FPC you really need another phone to compare but you could write down the measurements and check them on the ZXW iPhone 6 board view I think they show the resistance and they would be similar.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
pts8091 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 278
