주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
745 질문 전체 보기
Replacement Trackpad doesn't work
I replaced the Trackpad with one from ifixit. The cursor is responsive however clicking doesn’t work, the Dock doesn’t respond or appear at all and I cannot open any menus .
I checked everything and even repeated the process and made sure the connections were secure.
I replaced the new with old and functionality returned other than drag and drop which is what prompted the upgrade in the first place.
Cheers
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
To help isolate the issue, try using an external USB mouse.
Make sure your battery isn’t swollen.
There is also an adjustment screw on the trackpad. See step #9 at the very bottom of the photo on this guide:
MacBook Unibody Model A1342 Trackpad Replacement
UPDATE
If you are getting the same symptoms with an external mouse, it’s a very good bet the problem in not with the trackpad. My guess would be a virus. Start up in Safe Mode by holding down the Shift key and tell us if the problem persists,
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
I tried my usb mouse. Same symptoms. No Dock, no drop down menus, no access with clicking. Battery is 4 months old and fine. I am not a novice.
What happened in Safe Mode?
댓글 달기
Here’s a picture of the adjustment screw
해당 답변은 도움이 되었습니까?
점수 1
댓글 13개:
What does it adjust?
The green screw adjusts the point the down pressure click is reached. You should hear the click and the system should respond to that point as well.
I often find when I replace the trackpad I can encounter it rubbing on the sides. To help prevent that I use a Post-It Note on the inside surface of left & right sides of the hollow with adhesive side to the case. Then carefully tighten the Orange screws and pull out the papers. This makes sure there is a gap between the sides.
The old trackpad is back in and works but it is lacking in functionality.
@Tim Harding - Define what you mean by 'functionality'
The curser moved left to right as well as up and down across all parts of the surface? Does the click action work at the lower center point as well as the bottom left and right corners. Two finger actions also work?
The reason I wanted an upgrade was because I could no longer drag and drop. Click action works on my old trackpad in all areas as well as two fingers action. On the new trackpad I could move the cursor but click and tap were non functional. The cursor would not make the dock appear nor activate drop down menus.
댓글 8개 더보기
댓글 달기
귀하의 답변을 추가하세요
Tim Harding 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 88
