주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
Weak Wifi or poor Signal
This iPhone only sees near WiFi networks. The more far away the router the more poor signal
I have replaced this antenna:
iPhone 6 Plus 5GHz Wi-Fi Antenna
And no differnece
SHould I try with this?
iPhone 6 Plus Wi-Fi/Bluetooth Antenna
Thank you
Update (09/27/2019)
Hi, no antennas have fixed the problem. It seems to be a hardware issue. I will send to my friend’s lab to see if it can be fixed. I will post the results. Thank you
Replace a torn or missing Wi-Fi antenna compatible with the iPhone 6 Plus model #A1522, A1524, A1593. Fix unreliable connectivity to Wi-Fi service. 이미지
제품
$23.99
Replace a torn or missing Wi-Fi and Bluetooth Antenna compatible with the iPhone 6 Plus model #A1522, A1524, A1593. Fix unreliable connectivity to Wi-Fi and Bluetooth service. Part #821-00128-A. 이미지
제품
$22.99
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
I would like to suggest a cheaper way than replacing a router? But you need jailbreak for this. You can install SignalRefresh Cydia Tweak on your device and boost the signal strength. The tweak is available in Bigboss repository in Cydia apps store. If you feel you need to try this but do not know about jailbreaking will www.cydiacloud.com be useful
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hi @macpatagon
Have you tried to update or restore the software? Sometimes weird issues can be caused by third party apps and/or software bugs.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Flavio 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 44
전체 시간: 205
